After replace rear tire a strange sound begin. I try cleaning and lube the chain (chain wax & PJ1). Also torque rear nut 72.5- 73.5. But still the same @#$# sound. Any advice,any help or where to look now.
Ok guys. Tire maxxi 200/55 ; Only when taking off from a full stop on 1st gear only when relese the cluth lever and no down shif problem ,no sound (at least I can't hear)during shifting. Sound like a misaligment chain/sproket, chain slack about 1/2 inch. Like a clicking sound but loud.
is not too tight and there no rubbing on the tire, but I notice too much freeplay on the sproket/hub against the cush drive not side to side against the axel.
<!--EDIT|elmejor
Reason for Edit: None given...|1102602037 -->
which way front to back like the chain goes or side to side (looking from rear left to right)?
are you sure you installed the spacer between the wheel and cush drive?
