Rear Brake Caliper/Pads - Scary Post - Need Help
HayabusaLTD
Okay scary story first...I was riding home from work yesterday morning and hit morning rush hour traffic when the interstate I was riding on came to a stand still through a construction zone. The cars in front of me came to a complete stop and I had no choice but to slam on my brakes. I went to apply my brakes and when I pushed the rear brake lever down it seemed to have no pressure and just went all the way down without slowing the rear wheel so I did the WTF panic and compressed the front brake lever hoping to get my busa stopped before it became inbedded in the back of a pickup truck. I got the bike stopped after using the shoulder of the road and passing 2 stopped cars in the process. I looked down and pushed the rear brake once again and it built pressure back up but still would not stop the rear wheel. I still had about 15 miles to my house so I just took it easy (even after meeting up with a fellow unknown busa owner that wanted to have some 100+MPH fun) I got home safe and looked down at my rear brake caliper and to my suprise the entire thing came off the brake disc due to the 2 bolts holding it on falling completley out.
Okay enough rambling...My question is now that I have my brake pads as tight as they can be up against each other how do I go about getting them apart? Bleeding the lines? I also need to replace the two bolts that hold the caliper up to the brake disk, what size are they and how long? Any help would my greatly appreciated!!! :please:
GIXERHP
The only way to move the pads, at this point is try to wedge a screwdriver between them!
If you dont want to damage the pads at all open the bleeding screws.
As for the bolts, they are a 8mm by1.5 flange bolt, im not sure of the length, but ill measure 1 when i get home!
HayabusaLTD
Cool so if i just buy new rear pads (which wouldnt hurt probably) i can bypass bleeding the brakes and just pry the pads apart with a screw driver? Also where would i find a 8mm by1.5 flange bolt easier? Auto parts store or Lowes? Thanks!!!:bowdown:
TruWrecks
Banned
Use a flat screwdriver to gently pry the pad back apart. Go slow so you don't damage the piston seals. You shouldn't damage the pads if you go slow.
V-Max 2 Busa
Don't go prying on your brake pads, simply remove the pads and use something to push the pistons back into the calipers, I use a small C-clamp (1 1/2" I believe) available for a couple bucks at Home Depot. I also use small pieces of wood or plastic against the jaws to prevent any damage.
Acehole
The crowbar!
Don't forget to remove the fluid rez cover and watch the level as you compress the pistons back in so it does not over flow. If the fluid level is less than 3/8 inch in the rez when you first open it up, then you may already have air in the lines and will need to bleed them.
UncleSteve
Gear good - roadrash bad
Red loctite, yes 4 sho. I still have not got my back side un puckered:lol:
If you use red loctite, heat has to be used to loosen the bolts.
Blue loctite does not require heat.
Properly torqued with blue loctite is all you need.
See your dealer for new factory bolts. You want the same grade and quality bolt something a hardware store may or may not have. Piece of mind is worth the extra cost and the wait (if they don't have them in stock).
Commuta_Busa
Buy the bolts from a dealer/bike shop. Don't try and replace them with some lowes bolts. If you don't have a shop near you then just order them online from a vendor. Do what everyone else said. Gently pry them apart, open the resevoir cover, etc... Once you reinstal everything it doesn't hurt to bleed the system.
Mr Bogus
Trouble Makers Inc.
I would also advise you get some "panic braking" practice..
I can tell you if my rear brakes fell of and I was in a panic situation? would not even matter..
If I am stopping that hard, the back tire is going to be just touching the ground and the rear brake is only going to lock it up.. the motor and front brakes are doing all the work.. It is rare that I use the rear brake much in every day riding unless the streets are wet or I am on really bad surface..
You might PM GoldenChild, he has tons of this stuff laying around btw..
my68camaro
You mean my busa has a rear brake...where ??? J/k but seriously i have highsided a bike due to using the rear brake in a oh sh!t situation and locked the back tire up so now i dont even touch it except to make sure the lever is free now and then
rubber2burn
What I want to know is why were you using the rear brake to begin with it is only 25% of your stopping power you should be using the front brakes. If you use your rear brake it could possibly cause you to low side or high side the bike depending on the situation. Also if the rear pads were changed and some one did not pump the rear brake after completing the job that could have been the cause of the rear brake not stopping the bike need to pump that rear brake lever and see if it tightens back up. As far as separating the pads I use a large chisel and put it in between the pads to separate a little and then use a small C Clamp to finish the job. Also release the pressure by doing what others have stated.:beerchug:
Powers739
Now that's some good advise... of which I totally endorse and practice myself.
mike1180
Banned
They make a special tool to spread the pads apart.
It is cheap and works great.
You don't need it but it is nice.
(I love all tools)
Harbor Freight probably has them;
Spudley
Grippin' and Rippin'
Uhh...errr...ummmm those two bolts with the 12mm head on them ????.....8mX1.25 not 8MX1.5. That would be a very aggressive coarse thread.....
HayabusaLTD
Thanks for all the great advice from all of you! I just took the pads completly off and was able to compress the pistons with my ("strong") hands. I ordered the bolts and should be in within a week.
As for panic stopping experience I have plenty of it believe you me, people around Little Rock, AR drive like they are the rulers of the road and act like the nearest gas station is giving away free beer, chewing tabacco, and cigerettes to the first 10 customers. The main reason I went into pucker mode was the fact that I was expecting to have a stopping tool and when I tried to use it there was nothing there to use. I very rarely even touch the rear brake except when it comes to panic situations then I use that extra 25% of stopping power.
Thanks Guys!:beerchug:
Thread starter Similar threads Forum Replies Date
Mythos Front and Rear Brake Caliper Removal, Gen 2 Hayabusa Maintenance and Do-It-Yourself 1
B Rear brake caliper with play or rigid? General Bike Related Topics 1
F Underslung Rear Brake Caliper Gen 2 Gen II Busa Information 32
JINKSTER Rear Brake Caliper Help...pretty please?..LOL! General Bike Related Topics 14
C Rear brake caliper removal Gen II Busa Information 3
irishbusadude rear brake caliper Maintenance and Do-It-Yourself 3
D rear brake caliper hangers Appearance mods 4
S will a gen1 rear brake caliper fit on a gen2? Gen II Busa Information 16
wardie Rear caliper Brake Bleeding the easy way Maintenance and Do-It-Yourself 4
wardie Rear Brake Caliper follow up Busa problems 13
J where to find chrome rear brake caliper? General Bike Related Topics 6
Powers739 Rear Brake Caliper Maintenance and Do-It-Yourself 10
ItsDooomz FS: extended rear brake line, ABS model Busa Parts and Modifications 0
mitchelldanger Why won't these Galfer Brake Pads fit back in the rear brakes? Parts and Modifications 35
B Rear brake torquelink bar General Bike Related Topics 7
J Rear Brake Movement Busa problems 2
Narcissus Rear Brake master cylinder rebuild - Piston seized Maintenance and Do-It-Yourself 12
N Rear Brake Resoviur Gen II Busa Information 10
N Rear Brake Resoviur Gen II Busa Information 21
michael parris heuberger Help Rear Running, Brake,and Turn Signal Lights Looking For Leds Electrical Mods 2
piratediverjefff Rear Brake Line Gen II Busa Information 2
InfiniteReality Want your rear signals to act like running/brake lights?? Install a SMART Triple Play Gen II Busa Information 7
Dark3 Please help, 2013 rear brake line Busa Mods 8
Nefarioc Issue with Rear brake bleeding Maintenance and Do-It-Yourself 10
BusaBaker Need Help with Rear Brake Adjustment General Bike Related Topics 8
StenBusa Rear Brake Reservoir General Bike Related Topics 15
Dr Pain 2000 rear brake issue Busa problems 10
E Need some help finding a better rear brake mc General Bike Related Topics 5
007MI6 2013 Rear Brake ABS Recall Maintenance and Do-It-Yourself 5
LiBusa Rear (Hand) Brake Control for 03 Busa General Bike Related Topics 13
ogre modify rear brake/adjust sensor/modify shift rod after buell peg mod General Bike Related Topics 9
M Rear brake pads.. How to replace? Maintenance and Do-It-Yourself 5
B Rad +6 how lond of rear brake line do I need? Gen II Busa Information 4
F What is the difference between brake and rear wheel horsepower? General Bike Related Topics 14
J Rear Brake adjustment advise Maintenance and Do-It-Yourself 4
P Rear brake line needed please Pay It Forward - Members helping Members 8
Mythos GenII Front and Rear Brake Fluid, Clutch Fluid Bleed/Drain Maintenance and Do-It-Yourself 6
Mythos Sato Rear Brake Light Switch -? Electrical Mods 2
M Rear brake lockup Busa problems 9
P rear brake prob Busa problems 12
GNBRETT Tinted Rear Brake Lens Gen 1 General Bike Related Topics 4
WACKEM1 Rear brake adjustment Busa Mods 3
givenscg Billet rear brake reservoir??? Appearance mods 7
I remove rear brake for drag racing 1/4 Mile 15
JINKSTER Anyone gotta Gen1 Rear Brake Rotor They waana off cheap?.. General Bike Related Topics 1
Tufbusa Another Rear Brake Getoff General Bike Related Topics 17
JINKSTER Hey! Need a lil "Rear Brake Help" here...pretty please?... General Bike Related Topics 22
F Question about adjusting rear brake General Bike Related Topics 26
gagesdad Rear Brake Res General Bike Related Topics 21
VTbusa77 Rear brake light not lighting up all the way Gen II Busa Information 4
Similar threads
Latest Bikes
Forum statistics
Threads
174,616
Members
48,507
Latest member
cmgtsme540
