I knocked my '05 off it's kickstand in the garage (nice smooth concrete floor), did very little damage and seemingly only scratched the mag cover a bit. However, since then after I ride and put it on the kickstand I'll get maybe five drops of oil under the mag cover and the bottom of it will have a little oil. If I put it on a wheelstand so it's verticle, no drips. After about an hour, there are no more drips. I've tightened up the bolts on the cover - no change, replaced the gasket - no change, and added some gaskets to the cover bolts - no change. It seems the oil comes from the cover bolts on the lower 1/3 of the cover, which would make some sense, but it should have been easy to stop. I've less than 5,000 miles (still OEM tires!) and this was the only time it's ever been down. The mag cover doesn't show any cracks or damage.
Any clues out there?
