TRALL
Need some help......I have a oil leak and traced it back to the valve cover (I think that what it's called) that cover that sits directly on top on the motor and directly under the gas tank and frame. It appears to be a small leak at the very end of the cover on the right side, there is a half circle shape from the top cover that mates with the engine block and that is wear I see the fresh leak. The leak is small where my oil level did not make a change you could notice at the sight glass.
?'s
How hard is it to replace the valve cover gasket?
What would cause a leak there?
Is that what the black top cover is called?
By Doing the mods. mention below cause the valve cover gasket to leak?
I have a 06 Busa with 2000 miles and this past week did the following mods's- installed power commander III, and did the marble mod. on the air hose that was listed here at the org, I have aftermarket exhaust. By doing these mods. cause a leak on the valve cover gasket? After I did these mods. I went for a short drive and when I was stopped in front of my garage door a saw a puff of smoke caused from oil dripping on my exhust and then went to find the sorrce of the leak. After wiping the oil residue I found, I left the right panel off and went for a short drive around the blaok and then I could see the fresh oil on the right side valve gasket?
Thanks in advance for any help
?'s
