I was recently doing some work on the Busa and had the rear tail section off. Long story short, like a dumb a$$ I put the hump on without reattaching the locking mechanism. So, how do I get the hump off now?
So what you are saying is that you removed the little green clip that holds the lock?
If you remove the undertail,you should be able to reach up at the key lock and open it with the key.
