This is the Dyno I had done today- need expert input on what air/fuel ratio is best here, and most of all some guidance on adjusting fuel maps to change ratio. So, big question-
If the air/fuel for instance is 13.1 and you want to change the number on the map to increase it to 13.2, how many numbers do you subtract? Let's say the number in that square on the map is 5 and you want to reduce fuel to lean it out to 13.2- do you change it to 4, 3, or what? I'm sure there is not an exact correlation, but how about a guideline?
Below is dyno run and map, any knowledgeable input would be greatly appreciated.
