Warrior58d
I am trying to install a Clear Alt tail light and intergrated turn signals. I want to delete the stalk signals and cut the tail down sort of a poor mans undertail. I have everything hooked up so far but since I suck as an electrician I can't figure out which wire is the positive wire to splice into. the turn signal has a Black with a white runner and a black wire. The bike is an 03 and I have looked through the service manual but can't figure it out. Any help would be appreciated. Also If I clip the wires running to the stack and splice them together would I create a hot loop or will it still work like there was a light bulb in creating the circut. I want to use the stack wires to keep enough wire to reach the harness that is why I ask.
Regards
John
P.S. Sorry just realized I put this in the wrong place.
<!--EDIT|Warrior58d
Reason for Edit: "Put in the wrong place. Should have been in electrical"|1143502195 -->
Regards
John
<!--EDIT|Warrior58d
