Okay here goes guys...my "busa ignorance" in all it's blooming glory...just picked up my new-to-me busa and have the following questions....
1. Even after full warm-up...if I "Repeately Blip The Throttle" (to about 3-4K rpms) from just off idle and then blip as the revs are coming back down to almost idle...I can get this metallic clacking sound to happen...almost as though there's some slack/play in either the primary drive chain or...maybe even a loose clutch hub...(best way I can describe it)...is this normal for a busa with just 1,600 miles on the odo???
and...
2. I only thought the clutch assy on my FZ1 was noisey till I heard the one on this busa....at idle the clutch sounds like a maytag on aggitate cycle...is this normal???
Under power and under way the bike is smooth as silk and just thrums along with authority...I'm guessing I'm just not used to all this extra engine/clutch racket when just blipping the throttle or idling and thinking that maybe it's some sort of buffer clutch or something...any advice???...should I worry???....or just ride and quit blipping the d@mn throttle while idling???
T.I.A. & L8R, Bill.
and...
T.I.A. & L8R, Bill.
