I'm having a similar problem. I have the C.A. front turn signals and wired it up like the instructions said, and they worked....ONCE! Now they don't work at all! I know I'm going to have to rewire them and I have done a search on this forum and found some explanation, but I'm definitely NOT an electrician and don't understand! Will any automotive flasher work and do I need to undo the part that came from C.A.? Any help would be greatly appreciated!
Turnsignal Fix
Just finished this one up in 20minutes.
Yup any Electronical Automotive Flasher (2 pole) will work. Local Automotive retailer will have them. I went with the high dollar 15year warranty flasher > 8.95 < versus the cheap'0' 2.99 "silver can" flasher. You even get that clip-clop / clip-clop sound like in a cager. (Can't hear when running) Did'nt like the resistor / box option as this puts xtra loading on the circuit...why burn the xtra load/amps when not necessary.
