1stBusa99UK
I need some help, I am from the UK (England). I just got a 1999 Suzuki Hayabusa S/Hand, it has done about 35,000 miles and I am getting a Noise from the Engine, It has been to a Suzuki Dealer (NOT where I got it from, Setup Valves wrong, Did not do Full check on bike before letting me have it, just new Chain, Tyres and MOT) to have the Valves, Jets and have a look at the Cam Chain tensioner and he tells me, Suzuki Dealer, that all is OK with them (setup right,after he had re-setup the Valves and Jets).
Anyway I only get the noise after the engine has warmed up (Normal but mostly when Hot) and I can only hear it on revving up the engine a bit and letting it go back to idle, its a knocking noise (Sounds like its coming from the top of the tank) going from sort of fast to slow before idling (its on the Right hand side, which makes me think that it was the cam chain, but can not hear it on start up or if the engine is idling when hot).
The Dealer told me it may be a damaged clutch basket moving around or the cam chain, but he can only tell if he takes the engine a part on that side (and that is not going to cost much) apart from that the bike runs like a dream when moving.
Can you please help
, I am stuck with what to do
P.s. Very Sorry about an spelling errors, not my best area.
<!--EDIT|1stBusa99UK
Reason for Edit: None given...|1083707903 -->
Can you please help
