johnnysbusa
i have an 06.with 16,000 on it. seems like when the engines warm i hear a slight knocking noise at an idle? i ask other people if they can hear it, but no one seems to? im on the bike and i know i hear it. only at an idle, not at any other speeds. the bike is stock, i bought it with 13- thou on it. sounds like a lower end noise?? anyone else hear a noise like this on theirs? they just that noisey? or is it me.with the stock exshaust and sitting on it, sure sounds like you can hear alot of the engine noise... any help? ive been reading alot of good posts on this site. you guys and the site are awsome. keep it up! thanks
Probably just clutch noise....they all do it. If your throttle bodies are out of sync it will be louder.i have an 06.with 16,000 on it. seems like when the engines warm i hear a slight knocking noise at an idle? i ask other people if they can hear it, but no one seems to? im on the bike and i know i hear it. only at an idle, not at any other speeds. the bike is stock, i bought it with 13- thou on it. sounds like a lower end noise?? anyone else hear a noise like this on theirs? they just that noisey? or is it me.with the stock exshaust and sitting on it, sure sounds like you can hear alot of the engine noise... any help? ive been reading alot of good posts on this site. you guys and the site are awsome. keep it up! thanks
Yep the first couple years had cam chain tensioner issues. I've read of quite a few losing a chain like yours at low miles. Because of that and the starter issues (also a big $$$ fix when it frags the gear and cases) I wouldn't buy an early model busa. Best thing is to be SURE the recalls were done and upgraded parts installed before you buy the bike, or ride it if you've already bought it and its still running goodsame thing on mine (1999, 7000 miles), too. about a month ago (4 weeks to the day, actually), the knock changed and got a little bit louder...about a mile later, the cam chain tensioner let loose and I'm pushin the bike :11doh: . leads me to believe its from the valvetrain.
IMO Suzuki motors have always been a little on the noisy side. Maybe it's time to adjust the valves for a start?
You get those recall issues fixed up and you'll have a rockin' bike You have 1 of only 2 years where the busa came unrestricted....and changed biking historyBig red one ---yea, ill check into that starter pinion issue too. thx
(sorry for getting off topic)
