Hello Busa Buddies,
My K8 has 25,000 miles on it. I have been good about oil changes and have used 4T Mobil 1 Since break in. Oil level has always been fine and still is.
I have had no significant issues with my Busa.
Last weekend I pulled the bike out, it started normally and I sat for about 30 seconds to let things warm up. Just as I think about putting it into gear, the engine sputters and I hear what seems like mechanical noise.
As soon as I say WTF! The sputtering/noise stops and I am left with a ticking noise.
I shut the engine down and started doing my research, I hoped it was the clutch bolts loose, no such luck. Valves have not been touched or adjusted to date.
I searched this forum and found various possibly related items, but nothing exactly like this.
I decided to restart the engine and use my stethoscope. Ticking was coming from the valve cover, possibly near timing chain side. I pulled out the cams, certain I would find something. No luck so far, no evidence of wear, damage or debris.
Everything Cam, Tappet, shim, etc, looks brand new. I used my finger to push each tappet down, checking for broken springs.
Timing Chain tension seemed snug, especially for low RPM's
Now for the big questions, WTF happened and where do I go from here.................
My thoughts are to re-assemble top end, then re-set timing and check cam/tappet clearance. Then rotate the engine by hand to see if I hear any noise, or see anything.
Before starting I thought I would change oil and look for debris, Ill also cut the oil filter apart to see if it ate anything.
Hopefully I dont have to go into the head lease:
Any advice is welcome, Thanks!
Regards, John
Regards, John
