I posted this in pashnit's sponsored area but not alot going on there so I figured I'd take it to the place it really fits...busa mods...my favorite so far if I can just get it working!
Ok so I'm a bit stuck with all this stuff plug n play doesn't exactly describe what I'm dealing but at the same time this would be my first hid install....
So I've got the fuse part connected to the battery running up the right side of the bike to the ballast for the hid...then I'm dealing with a few cords off the fuse area I have a connector with blue n white wires that I believe according to the instructions that needs to plug into the positive of both the high n low beam connectors which I don't understand because I thought the high beam was just connected to the original high bulb and installed the regular way I have the new hid connected to the ballast and it powers up just fine when I turn the bike on, but the light out put seems to be aimed straight down to the ground I can only see like 3 feet in front of me and the light output is dim
The ccfl halo I haven't even figured out how to power it yet I see the kit came with a switch but I thought it could be hooked up straight to power and come on when the bike does there is a lil box with two wires one red and one white that look like they need to be spliced into something I'm assuming this is what powers the halo and that this is the only wire that needs to be spliced and it should be spliced into the extra connector on the original wiring harness next to the right right turn signal connector?
Sorry for the long post and I hope my questions can be deciphered outta all that lol....
If anyone has any advice id be so grateful
I'm just a newbie but with a lil advice I'm sure I can get this set up correctly
