Injectors not spraying
Dcroes92
Removed fuel tank to remove rust ...assembled back together connected fuel line and plugged pump harness...
Gauge stopped working and pump wasnt priming
Noticed blown 10A fuse was blown replaced and gauges started working again and pump is working ...
But now motor is cranking and pump primes
I do have spark but none of the injectors are working
I have voltage on yellow/ red wire but im not sure if ecu is damaged or so...any ideas on how to check ?
Maybe your injectors are plugged with rust. Just a thought. If your gas tank had rust good chance your injectors got clogged
