heavy duty output shaft and roller cam chain conversion??
IRDEATH1340
at what hp do these items become an absolute must, would 300 hp make these a must. I thought I had everything I wanted for my build then came across these. I know they would be beneficial but not having unlimited money will stock shaft and cam chain be ok?
oldgixxer
Once you are 450+rwhp thats when you should consider needing the HD output shaft. Only know one or two people that have done the roller conversion,so I dont know if its *really* needed or there for peace of mind
IRDEATH1340
appreciate it, definitely saving me some money then...just deleted a few things from my shopping cart forgot to mention what about 1/2 studs since the engine is out? or just go with the normal sized ape stud replacements?
Blackmax
When Steve Knecum did my motor this winter he had a list of things he felt were needed to make my motor Last , I had a super duty HAYABUSA TRANSMISSION OUTPUT SHAFT From APE put into my 1441 its a week point and whats $300 also a Pro Series tensioner is a good Idea since OEM Suck and studs were like $80 . So for another $500 I dont have to worry about it . Yes Its at 240hp, but the at what point # is not something I wanted to worry about when the motor was all apart anyways
oldgixxer
Well,if you have the money it will cost a lot less now to install 1/2" studs. And if you're doing the 1/2" studs you will be making big power so you will need that HD output shaft.
Sit down,think about what your horsepower goals are down the road. If you even think that you will want more boost then you need to map out a game plan before you tear the engine open. Trust me when I say that you will spend 2X more if you do it later then if you do it from the get-go. You will drain your bank account very quickly with a misguided turbo build.
Even if you have to wait awhile,its worth it it the long run to have all the required supporting mods. If you're already asking about the big studs and the output shaft then you should probably go ahead and do it now.
POWERHOUSE
Frank
ARP stock diameter cylinder studs will take you just over 400 rwhp, APEs will not. I would not go over 350 rwhp with APE studs, just my preference. The 1/2-20 cylinder studs are needed if your goal is 450 or better. I would do the heavy duty output shaft on any turbo because of the torque we see on boost, especially if the bike is being launched from a dig. Of course, the foregoing is IMHO . . .
GNBRETT
I opted for the roller cam chain conversion with my current build. if everything is apart I don't see why one wudnt go with it. is it necessary? well, I can think of a dozen parts that aren't necessary but an ounce of prevention is worth a pound of cure.....:whistle:
MR2liter
Like powerhouse said. . I think ever turbo bike needs the billet output shaft however the rollerchain is not nessasary... I opted to go with the roller chain and it's working out fine.
Blackmax
Like Frank said ARP Studs , thats what I had put in . Yes mine is not a Turbo but I hate what if's and you might as well make it bullet proof while its apart
Boosted Cycle Perf
Site Sponsor
If it's a gen 1, billet shaft all the way. I've seen stock gen 1s snap output shafts. The gen 2s are 5mm bigger, and don't seem to break. I've done some gen 2s with them, some without. But it never hurts to do it.
IRDEATH1340
ok getting the hd output shaft, and arp studs. are gen 1 and gen 2 the same studs? all I see show 99-05 years, seems like I saw somewhere they were the same part number 271-4701 on the arp website. I have a gen 2 btw
POWERHOUSE
Frank
The cylinder studs are the same. BTW, one of the differences between the Gen 1 and Gen 2 output shafts is that the Gen 2 output shaft sticks further out from the motor, it is a longer shaft and subject to more flex under load. Another reason to change it on high torque bikes . . .
Kevin Jones
The roller cam conversion says that degreeing cams is not necessary. How is this possible or am I reading it wrong? It seems to be the same cost for a roller kit (post spacer) as for adjustable sprockets and an OEM cam chain so it seems a potentially sensible upgrade although it does say that some trimming is involved. I just don't understand how it could not need degreed.
APE Roller Cam Chain Conversion Suzuki GSX1300R Hayabusa (99-15) - Schnitz Racing
Thread starter Similar threads Forum Replies Date
ColdBusa Heavy Duty Output Shaft Sprocket Engine and Performance mods 4
EvoChrisLee Heavy Duty Output Shaft All Motor 9
J Gen 2 heavy Duty Output shaft Engine and Performance mods 3
J Heavy Duty Trans output Shaft Gen II Busa Information 0
A Iso Heavy duty fork springs General Bike Related Topics 2
Ham Heavy Duty Springs Gen II Busa Information 8
rubbersidedown *free* Really Nice Heavy Duty Motorcycle Tie Down Strap General Bike Related Topics 6
TYJUAN WALTON Heavy Duty Front Sprocket Cover Busa Mods 5
Energizer Heavy Duty Clutch plates for Super Charged Busa 08+ Super Chargers 16
all4sho Trac Dynamics Heavy Duty Rear Shock Help Gen II Busa Information 7
0 Heavy duty clutch springs Turbo 8
jermzfree When do you need heavy duty head studs? Turbo 12
BLKMAMBA Heavy Duty Battery General Bike Related Topics 23
U Heavy duty spring for rear shock.... Gen II Busa Information 11
card16969 heavy duty oil pan? All Motor 16
Fastfrog007 ATC heavy duty spring info.... General Bike Related Topics 9
hayabusa99b/w heavy duty valve springs do u need aftermarket retainers? Turbo 7
Fastfrog007 Spring rate? Heavy duty spring? General Bike Related Topics 5
B APE Heavy Duty Clutch question Gen II Busa Information 1
T heavy duty rear shock General Bike Related Topics 5
kingbusa Heavy duty spring for 300 kit? Busa Mods 9
zukracer Working on a project - Anyone have access to heavy duty draw slides? Random Thoughts 12
S New Heavy Duty Cush Drive Rubbers General Bike Related Topics 29
Y Need some heavy duty parts. General Bike Related Topics 3
jjbusa Heavy Duty Rear Shock Spring General Bike Related Topics 3
B APE Heavy Duty Starter Gear Racing Technical 2
G heavy duty clutch springs? General Discussion 2
O Free heavy duty engine stud kit General Discussion 6
O Heavy Duty clutch springs General Discussion 1
WuzzaCBXRider Heavy rotors Random Thoughts 4
R Heavy hitter seat pan General Bike Related Topics 3
S Who makes a heavy front axle for our bikes? Gen II Busa Information 7
D Lot of smoke under heavy throttle? Turbo 10
SSGT_B Unstable Heavy In Turns Busa problems 34
fallenarch Heavy Bikes Scare Me! Other rides of our members past and present 28
Rivercop UK My Busa Christmas Garage Modification (pic Heavy) General Bike Related Topics 8
D With a heavy heart I come to you this morning Random Thoughts 6
VaBusa It is with a heavy heart that I report... Random Thoughts 33
D So it is with a heavy heart Random Thoughts 38
B Shipping long/heavy exhaust? General Bike Related Topics 8
Boosted Cycle Perf Anyone interested in a pic heavy build thread? Turbo 55
limpytheduck Need opinion about riding in heavy rain General Bike Related Topics 18
D It is with a sad and heavy heart that I must report... Random Thoughts 12
SLEEPERBUSA SLEEPERBUSA's 8 second heavy hitter, all motor, streetbike. 1/4 Mile 25
RMS2005 Is it done yet, prolly not!!! ( Pic Heavy ) General Bike Related Topics 18
Audiomaker Riding a Turbo in Heavy Rain? Turbo 27
SoCal Blur Track Day Electronics GPD w/ ATRE (Picture Heavy) Busa Mods 9
Lurch Pictures from todays Holy Hill ride. Pic Heavy (100+) Random Thoughts 29
Gpmo Utah in a week (pic heavy) Trips and Touring 13
red1100cc Org Hoons return from Sturgis. (pic and fun heavy!) General Bike Related Topics 59
Similar threads
Latest Bikes
Forum statistics
Threads
174,642
Members
48,516
Latest member
Jayabusa77
