Go Pro Questions
04Duramax
Soooo I'm pretty sure I'll finally be getting my GoPro for fathers day coming up :thumbsup: and my question to you guys is how do you mount yours on your bikes? I was thinking of doing the helmet mount, but was wondering what else you guys do. I have a dark smoked windscreen so mounting it off handle bars prob won't work. Does anyone use the suction cup method? I guess I'd be a little gunshy mounting a $200+ camera to a suction cup.
kromdom
wannabe HOON
if you have not yet done so, contact PASHNIT about anything and everything regarding mounting a GoPro !
Goatkart
Used correctly, the suction cup is a BEAST... its not coming off unless what ever its attached to comes off... I actually use the suction mount for random other tasks too LOL...
That means putting it on a clean surface, depress the center button a couple times to purge the air, lift the handle from horizontal to vertical to lock it in...
I have used the gopro suction mount at "significant rates of speed" and it didnt even wobble...
motochris
Suction cup is Awesome...believe me when I say No Worries there...100+ mph not a problem...rain or shine...this suction cup is great..enjoy!
Posted via Mobile Device
Blanca BusaLess
Suffers from PBSD
I only push the button once and then flip the lever. It's like Goatkart says that suction cup ain't coming off. I've had it mounted on side of fairing at speed as well. Only thing is it only captured a low/one sided view which wasn't really good. Since your windscreen is dark suction cup on tank won't work either so try this. I used one of the included 3m tape mounts and put it here on nose. The orange 'keeper' cord is actually the reminder cable from my NY disc lock.
But the most solid way to mount it in that area is to mount it off the mirror mount. Pashnit as mentioned can help there as I've seen him talk about some of his mirror mounts.
frisbee
GODSPEED RACING
I think I may be getting one too!:whistle:
Zoinks!
Suction cup is the only thing I've ever used. Used it on the bike, car, and the boat. Worked great for everything. Just clean off the surface you're mounting to, to make sure you get a good seal and you'll be good. I stuck it to my kitchen table and drug the table around the kitchen with it.... It's hard core.
PADEROLIS
Great minds...
04Duramax
Thanks to all of you.. I appreciate all of the info. I can't wait to get it....
PADEROLIS
Wow that looks low.. you haven't smacked it off there? Cool idea though.
So far so good! I've only done a couple of rides with it in that position though; maybe I'm not leaning the bike enough to cause it to smack the pavement!
skydivr
Helmet Cam baby!!
04Duramax
Helmet Cam baby!!
Where do you mount yours? I have seen quite a few people mount them right under their mouth vent for a first person view.. I would think it would get in the way of my line of sight though.
04Duramax
I am going to assume that my answer is located in the picture I can not see for some reason..
CCbusa05
Helmet mount is the way to go!!! I even wear mine in the house!!:laugh:
- ‪MSR‬‏[/url]
skydivr
I don't like it on the chin, too much to get into the way, and you would feel the weight. Mine is mounted on top of the helmet. It's high but you can see the road and usually the gauges too.
if the other pic didn't work, this one should...
Twobrothersbusa
Team Gixxer Racing; IDMBT #1
You are getting her done in that pic for sure....
