Gear Based Nitrous Activation?
smithabusa
Site Sponsor
What do most of you guys with stock wheelbase to tame the NOS in 1st gear? Progressive conrollers? Never go WOT in 1st?
If interested I can modify your gps sensor to output a ground signal for your WOT switch only in whatever gears you tell me you want it. So the NOS solenoid would never get triggered until say 2nd gear and on. Very inexpensive and works great for a lot of guys.
ColdBusa
Take this Jerry, you silly little rodent
You can get a window switch from Zex. That is what I've got. It gives you control to spray in whatever gears you want and at what RPM. Very good investment if you ask me. Just one less thing to worry about as you don't have to press and hold a button.
smithabusa
Site Sponsor
WHat do they charge for that setup? I can do window switches as well
ColdBusa
Here ya go...hopefully this works.
http://www.compperformancegroupstores.com/store....SSORIES
I know it is a little pricey, but I figured I should go everything ZEX..
smithabusa
Site Sponsor
Does it do Wide open throttle switch as well or no? I do the gps mod for $55 shipped, and could do a window switch for about the same price.
johnnycrash
A window switch that lets you select which gears it activates in?? I know the Schnitz window switch doesn't do that - I thought the only one that did was the BTC box which is expensive and hard to find.
Gotta link to this switch?
chevelle
I have one (taction control) brand new,never used. Paid 160,it will be going up for sale soon,as will the BTC box.
ColdBusa
The Hayabusa specific kit comes with a wide open throttle switch. When on the Zex.com site, just search hayabusa, then click sportbike nitrous oxide. Part# 82075 is the Hayabusa specific dry kit, and it comes with the WOT switch.
http://zex.com/
