This doesn't require any gps mods or anything, pretty simple.
To be used with horn button, i would assume most guys spraying are running an air shifter. Once you tap the air shifter once and are in 2nd gear, the box will let nitrous come on (made to work with my ECU nos harness) assuming the other window / wot / toggle switch conditions are met.
Even without an air shifter you could tap into the ground side of the horn, a quick beep of the horn whenever the bike is stable enough to spray.
this was the 1st prototype, have 2 out there that have been tested and worked as expected
