CorrodedAlien
Everybody has their preference. I just run the low grade stuff myself without any problems. I'm not a dragger or knee dragger either.
Really ? Hmm, that's weird, pretty sure my manual says to run 91 octane for my '02 machine. Hmmm, will double check tonight.my 2003 manual says to run 87. does it not run as high compression, or less agressive timing?
the old "oiler motors" LOVE 100LL! especially in a high humidity environment.Be careful with avgas, generally avgas is 100LL(100 octane low lead). That's not saying its unleaded.
Thank you for the clarification. I have ben running the Cheveron high octane. Will be checking out the "inexpensive stuff"WELL WAIT, I said lower octane, NOT the cheaper stuff. Someone posted that they were running some shop-n-go fuel and the Busa stumbled, they switched to Mobil 93 octane and it was fine. I argued that it was probably the Mobil vs. Shop-n-Go that made the difference. I suggest always trying to stick with the big petro refiners. In fact, I shoot for Chevron because the Technon detergent additive does in fact work. If that's not available, I shoot for 76, then Exxon, etc.
Run the good stuff, just not the highest octane stuff!
