Fork seal help. Too stiff after re-seal.
LeeFL2
I resealed my forks and they feel too stiff. I think I added too much fluid. Any help would be great.
mike1180
Banned
What was the weight of the fluid?
The recommended weight is 5W.
Also if you overfilled them, yes they would be stiffer.
LeeFL2
10 weight. I think I overfilled. fuk!
Tufbusa
Track Coach / TufPoodle Coach
If you put 10w back in those puppies, it will be much stiffer with your current settings. Back the compression and the rebound off a few clicks and ride it again. It should make a difference.
Did you do one fork or both forks?
How did you measure your oil (480ML)? Did you compress the fork cartridge until all the oil was out of it? If not, then you most likely have to much oil plus you have 10w which is twice as thick as the original 5w.
Sounds like you may need to disassemble them and start over?
By the way, to much oil means less air space and that will create a higher pressure as the stoke compresses creating more resistance.
mike1180
Banned
Hey Tuf.
Notice I didn't recommend 90W.
The old dog can learn new tricks! :whistle:
