Pull the right side fairing! I use Aluminum foil over the header to avoid oil getting on em, but there has to be something better than that! Be very careful with the drain plug! I use the Suzuki Oil filter wrench and Suzuki Filters.(speed750 @ Dec. 16 2006,09:23) Is there any easy way to get the filter off or do you pull the right side fairing? Any tricks or tips?
Thanks!
+1(carolinadoublej @ Dec. 16 2006,09:31) Also after you take the 3 fairing bolts out of the nose, run a piece of tape along the edge of the nose where the right fairing meets. If you are not careful, the tabs on the right fairing can wreak havoc on the paint when re assembling
Great idea! Thanks(8Daytona8 @ Dec. 16 2006,18:17) Also a heavy duty hose clamp secured snugly on the filter with a long extention and the 5/16" socket you can bump with a rubber mallet etc to loosen the filter. If its too tight for this to budge it you are not oiling it with OLD OIL or over tightning it! This worked on mine @ the 200 mile breakin oil change with factory over tight filter! and they really over do it!
