Speed
- Joined
- Jul 1, 2010
- Messages
- 15
- Reaction score
- 1
I have a 2003 Busa with 22,000 miles and my first gear is doing some strange things. At 7,000 rpm its LIKE the clutch is pulled in and all drive stops. It will rev as high as I let it with no drive. If i leave the bike in first and the rpm's drop below 7,000 'drive' returns. I normally shift before the 7,000 mark now to avoid it and the bike reacts normally in all other gears to red line.
Here's the kicker: if I'm downshifting into first the drive is there at 9,-10,000+ rpm and engine slows the bike down like it should. But as soon as I twist the throttle and hit 7,000 rpm the bike jerks and nothing.
Here's what I've done so far to try and fix the problem: New clutch, all o.e.m. plates, springs. Drained master, o.e.m rebuild kit, changed fluid(there is no slippage other then the whole 7,000 rpm thing). Checked the slave and it seems fine.
Any suggestions would be appreciated. Thanks
and if I down shift at 9 or 10 K my azz is washing out on me because it's locked up.
