have you looked to see what the code ment???? i have a simular problem, but i cant get it to through me a code.
thank u so much sixim going to try it rite now.
ok six i think i found the wire but it has wires coming out of both ends should i disconect one end?
Here ya go Tank
Under the driver seat there is a white plug with 4 wires in it. It doesn't plug into anything and it may or may not have a cap on it.
Use a paperclip or piece of wire to jump the red/white and black/white wires(this is safe and will not harm anything), this puts it into dealer mode.
The key must be on and it doesn't matter if the bike is running or not.
When done correctly you will get the letter "C" and a 2 digit number displayed on the dash. As said, C00 means no codes, anything else is listed below.
The picture also shows the plug with the cap on, but it's just easier to reach the pins with it off.
aww i have a gen1 busa will
ok six this is the only wire there it on the rite side of the battery.
I can't tell from the picture, but does one side of that white plug have the 4 wires in it like the picture above? And, Is the other side of it a factory wire? Or has someone electrical taped it up?
ok i think i got the rite one it showed c92 code
