stangman327
So I decided to do a little LED Halo visual comparo, expensive vs low budget. Both rings are 80mm in size. The black ring is a RGB light and the white ring is a pure white ring.
The black halo ring is from Sportbikelites which as you can see is sealed in a clear epoxy on the top which would have obvious benefits such as waterproof and shockproof. The back doesn’t have the epoxy coating but the board doesn’t have the exposed LED circuits also the wire/solder points are epoxy coated. The Sportbikelites kit consist of 2 rings the other being a 100mm ring in size.
The white halo ring is from Superbrightleds ($9.95 before delivery) as you can see it is not on the same level as the black ring as far as build quality goes but I’m saying its not any good also the white ring does not “feel†cheap in my hand. I guess it would work for someone on a budget.
The Sportbikelites kit cost me about $175 to the door which included the remote upgrade.
