WOOOOOOOOOOOWAs much as the stock internals will take... Should do a 100 shot with no problem. Some of the men on here are pushing the stock internals to the high 300s...
Yeah I know about turbos can go for 300+ HP but NOS are hitting harder and what I read before that on turbos it can hold till 300 BUT on NOS can be 250 or 280 maximum I don’t remember exactly, but it was not mentioned if it’s gen1 or gen2 engine what can hold all of this powerThe internal seem to hold up pretty well. Guys on here with turbos are really pushing them. Take a look in the turbo forum.
I will use ECU editor for sureNitrous hits harder if not ran progressively. You can progressively load it using the ECU Editor software. It's very easy. There is never going to be a definite answer, and the tune will always dictate whether it will live or die a quick fate.
Drag racing Mr. Brown@Aly Kabil what is your intended purpose? Racing or bragging rights?
Dustin what is ur setup?Oh yeah. Dry shot is very easy with ECU editor. That's how I do mine.
With the Bosch pump, right?Do the injector balance like they do for turbos and you fuel something like 380hp with the stock injectors.
You use the AEM 50-1200 in tank (E85)?I use the 320lph intank pump
Then I'd suggest looking at what @Boosted Cycle Perf is doing with stock gen 2 turbo kits.Drag racing Mr. Brown
