EchoBase
I have an 06 Busa with about 30,000KMS on it, BMC Air Filter, Full 4-2-1 Yoshi Exhaust, PC3 tuned pretty will and a full time PLX Wideband and Gauge so I can monitor AFR. I've changed the plugs in it about 10 days ago with NGK CR9EIX Iridium Plugs. Old plugs looked good actually.
I've changed my oil and filter twice since March.
The oil seems like its breaking down way too early.
Symptoms are that the engine, once it's up to temp, will idle with some minor noises in the bottom end, shifts are a little rough
When I changed the oil last, the engine ran so quiet and shifts were so smooth, it was a different machine, slowly, that has changed.
Since this last change (30 days ago) the oil level is a tad high definitely does not look the colour it did when I put it in( it's a tad lighter) and it smells like fuel, excessively so.
Last three oil changes:
Sept 2013 - Amsoil Synthetic 10W40 & Suzuki Filter
Feb 2014 - iPone Semi-Synthetic 10W40 & Suzuki Filter
May 2014 - Motul 7100 Synthetic 10W40 & Suzuki Filter
Any suggestions or ideas are welcome, thank you all in advance.
