I have a problem with my 05 Busa (red & black:-). It kinda roars and rattles
in neutral with the clutch out and gets quiet when I pull it in. My clutch
fluid has already turned dark with 2500 miles. I noticed with the choke on
that pulling the clutch in lowers the rpm's from 2k to 1k. When i rev the
engine in neutral from 1k to 2k (when hot) I hear the rattle bad . Sounds
like maybe a loose clutch basket. I've changed oil 3 times so far and have
some fillings on the magnetic drain plug each time. I've called the Suzuki dealer (Sloans) in Murfreesboro,Tn to have them look at it tommorrow. If the dealer says it's normal, should I get something in writing in case it breaks later on? It's in warranty. I ride with another 05 Busa and his doesn't make any of the noises and he has the same 2500 miles.
Any ideas?
Any ideas?
