F fxf Registered Jul 20, 2014 #1 Does anyone know what's the best way to clean the brown sludge out of the bottom of the overflow bottle/tank Thanks, fxf
Westbusa Registered Jul 20, 2014 #2 Remove the bottle and add some good cleaner and give it a shake,or a long bottle brush might work...
Rocketmn Registered Jul 20, 2014 #3 You can also use some White Vinegar and Warm water and just let it soak then rinse thouroughly. Depends how bad it is..
F fxf Registered Jul 21, 2014 #4 Thanks, Its bad.. I wasn't sure what cleaner to use. Tried bleach, didn't really work. Will try vinegar.. Thanks for the suggestions...
