ALLshow.NOgo
I saw a kit on ebay and thought this was pretty slick.
Do you want the ulimate in custom suspension for the front of your Hayabusa. Check out the front air-ride suspension. You will be one of the first with this incredible item. We can also get the option remote control that raises and lowers the bike upto 1,000 ft away.
This kit replaces the front fork assemblies and allows you to adjust the bikes ride height up or down just as the rear air suspension does.
This kit is chrome
http://www.spyderracing.com/Product....RONT-CR
This is the NEWEST and TRICKEST BILLET item available for the BUSA to date.
It is made by a company called TRICKY AIR and is BRAND NEW and available for your 1999-2007 HAYABUSA. The front end is made entirely of billet aluminum and Triple Chromed plated to finish off the trick design.
They raise and lower the front end of your BUSA by a small 3 position switch and a small air compressor.
All stock parts from your BUSA will float right together and it can be used with stock trees (using no fork caps) or aftermarket lowering trees (only with use of our custom Fork Caps) as seen in the pictures.
This kit is chrome
