little background about 2 weeks ago I noticed my bike was turning over a little slower than useual. battery died 2days later, I got a jump and was able to get home(about 17miles) with no problems. I got a new battery thinking it was just time for a new one. 1 week later I had to get another jump. so now I know I have a charging problem.
I used the trouble shooting chart in the service manual and have a couple questions.
battery is new charged for about 6 hours. after sitting for about 2 hours it read 12.9v. I measured charging voltage and it was at 12.7v (should be 13.4v-15.1v right?)
next I measured the continuity of the generator coil, it was .5 ohms. spec is .2ohms-.4ohms. so would .5 be good?
No load test showed 90+v @ 5000ish rpm so Im thinking the stator is good.
I tested the rectifier but not sure of the results. with the "+" on BR and "-" on BW, B1, B2, B3 all come up as over ranged. with the "-" on BR and "+" on BW, B1, B2, B3 and show in the 530 range. Im not sure if this is right, spec is .4v-.7v. the manual for my meter says if the diode is in the .5-.7v range one way and over ranged the other then its good. so Im unsure if the 530 reading I got is the same as .5v
before I did these test I went to get prices for a stator and rectifier. I told the parts guy at the dealership what my bike was doing and he said most likely the cause is the rectifier.
I look at all the wires to the battery, stator, rectifier and they all look good. so Im kinda lost now. any help would be great.
