kramykram
Ok so took my bike to dealer today for the above noise. They said my chain was to loose. After I left I was worse than it was before I brought back in. Now I get home and lift the rear. I'm rolling the wheel and feeling the chain. It appears to be tight in one spot and loose in the others. Now my question is. If it were the chain. Why does it only do it at a slow roll and as from the video you can see it stops once idled up a bit. I figured the chain is the problem. But seems it would be a constant problem not just a slow roll problem. Any able to help me out? I've read other post but only thing I saw was replacing the gears and chain.
