I have a sportbikecam mount. I added a 2" riser between the mount and the camera so I don't catch the fairings and dash. Not shakey when I get it setup right
<!--EDIT|BusaWhipped
Reason for Edit: None given...|1145418494 -->
... there are 2 important points for capturing sharp videos , first one is a good camera with image stabilizer build-in , second , a strong camera mount , here is my set-up , i'm capturing crystal clear frames with this set-up ;
ImageShack Links Do Not Work
here is an example frame from my tankcam clips ;
* You can get this tankcammount from ebay for just $27.95 , ebay item number is 4631372785 , goodluck
<!--EDIT|Guclu
Reason for Edit: None given...|1145479558 -->
