Ya know what, I bet it would work as good as brake cleaneryea but I already got this on hand... and it works 3 ways...
Gets the grime off, makes me feel better and gives me the guts to roll the bike over into these sidewall areas
are you crazyyea but I already got this on hand... and it works 3 ways...
Probably the smartest idea right there...prop it up securely, put her in first and hold some sandpaper up against the edges.it is pretty easy to rub dn w/ sanding sponge or paper. That you KNOW will work AND is safe
jeesh...no respect....I swear I made that suggestion nearly a dozen posts ago....lolProbably the smartest idea right there...prop it up securely, put her in first and hold some sandpaper up against the edges.it is pretty easy to rub dn w/ sanding sponge or paper. That you KNOW will work AND is safe
