Believe it or not your best bet is finding a Mom & Pop type shop in your area....major dealership parts dept. usually only carry oem application stuff but a Mom & Pop Joint hasta survive and most in-the-know will have and use a "Goodridge Custom Build" line station....where they can simply measure full extension then add an inch then pick out the correct length lines and then they use ultra high grade compression seal fittings to then select and attach the appropriate angle banjo fittings on each end....I used'em on my FZ1 (Dual Front & Rear) and again on my Busa (Dual Front, Rear & Clutch) with no problems and zero leaks on either...great stuff, extremely versitile, ready and there when you need it at any reputable and well stocked privately owned/operated bike shops.
L8R, Bill.
