BLEEDING BRAKES
OB_ON A BUS
CAN ANYONE OUT THERE GIVE ME GOOD INFORMATION ABOUT CHANGING THE BRAKE FLUID, eg WHATS THE BEST TYPE OF FLUID, THE BEST WAY TO BLEED, etc, ALSO BRAKE PADS, WHAT ARE THE BEST TYPE? ALSO ANY ADVICE ON THE BEST WAY TO CHANGE THE PADS
Pads Ferodo CP911.
Look at the temperature numbers on the bottle and go for the highest. Dot 4 is Dot 4, Dot 5 is Dot 5 you can NOT mix them. Unless you want to clean out your whole system stick with DOT 4 and buy what has the highest temp.
Brake-Tech(Ferodo, PFM, Nissin) and speak to Jeff or www.braketech.com
(805)376-9565
Gafler tech line
(800)685-6633
Brakelines contact Goodridge - Ben
(310)381-0725
