Yesterday I installed new brake pads and the Gafler brake lines. Now I in the process of bleeding the brakes, however, I am getting no pressure.
Take a look at the picture below. I have a very similar set up. The pump's reading has a reading of 15 on it, however, no fluid is coming out (there is fluid in the master cylinder).
I would think that after a moment fluid should come out. I tried this for about an hour and fluid never came out.
So next I tried to use the old fashion way....pump the brakek brake a few times, then while holding the brake down open the nipple then close the nipple, pump the brakes a few more times and do the same thing.
When I open the nipple I do hear air (pssss), however, never any fluid comes out. I tried doing this for about 2 hours and finally gave up.
Any suggestions......
