My brakes were begining to fade on my bike so I decided that it was time to bleed them. It's an '05 and I've not had to bleed them yet. I did the rear one first with no problem. Added fluid, pumped the brake, opened, pumped once, and then released valve and closed. I repeated untill fluid was flowing freely. The front brakes are where I ran into a BIG problem. I filled both the main (right) and left resivor. After I bleed the right brake, using the same method, I noticed that I lost a lot of tension in the lever. I then bleed the left and lost all tension in the lever. Pumping and releasing the lever I can get fluid to readily flow through the line, but I've now lost all pressure in the brake line. I was also concerend because the left resivor never moved. What could be causing this problem and how do I fix it lease: ?
