(Gixx1300R @ Jul. 07 2007,14:08)
(JINKSTER @ Jul. 07 2007,15:40) To be honest with you?...I have serious doubts and even more serious "concerns" as by thickening the billet stock as much as you have....which mandated use of longer bolts?...you've just greatly increased the leverage load on the cam caps which it is mounted to...which is already under engineered torque spec guidlines...and by raising the clamping point as high as you have?...you just increased the leverage and stress on those cam cap mounting points expotentially so?...
Speaking as a life long R&D Prototype machinist/fabricator?...i wish you the best but have serious concerns that you just may crack your cam caps when you hit sustained high rpms where that cam chain damper is working it's hardest at taming the wiley high rev cam chain dynamics.
L8R, Bill.
Jinkster you have always had serious concerns with no matter what I post. As a long time fabricater and engine builder I see a need to have over engineered parts. I have a keen understanding as to why the parts failed. I test not only harmonics but as sheer factors,heat expansion,torque factors as well as many other factors. The cam chain guide did not fail from high pressure factors. It failed from harmonics at it weakest point. Dont get the 2 confused.
actually?..i never claimed to "know exactly why" your oem damper failed...but i do know this...there's 10's possibly 100's of thousands of stock oem dampers that haven't failed...i would suspect any of several possibles from my viewpoint...some being...
1. The hole punched in the formed sheet stock damper propogated a crack...possibly due to micro-fractures about the hole..possibly from dull or inproperly administered tooling.
2. Defective Material...possibly due to...
a. poor alloying practices in a heat code batch of material supplied and/or..
b. Improper forming that resulted in work hardened/stress of the material and/or?....
c. Improper heat treat related issues and or?
a slight combo of allll of the above which resulted in a failed part...but i do know these three things...
1. Suzi went the distance in the weight saving department to go as far as to hydraulically suspend a magnesium valve cover in oil filled rubber grommet grooves using shoulder bolts...i find it ludicris to arbitrarily slam a huge hunk of aluminum in there in an attempt too..
2. Repair what seems to be an extremely small percentage of failed cam chain dampers...especially when a more logocal fix would be to simply weld a doubler plate on the existing part to strengthen it without slamming a huge hunk of aluminum under your magnesium valve cover and finally?...but most importantly?..
3. Dude...you have no idea how much extra load and leverage you are appling directly to the cam caps by using such long bolts...you've elevated the stress moment considerably on what are not just "cast aluminum parts"....but...cast aluminum parts that were designed to be as light and minimalistic as possible...i already have a good idea what the result is going to be in the end...sooner or later is anybodys guess.
and btw...your part is definantly overbuilt but it is in no way "over-engineered"...he11..you haven't even tested it yet.
and back on the farm?...i wish you no ill bud...matter fact?..i'm try'in ta save ya some possible future grief...for a 2nd time...
L8R, Bill.
