Bike not idling when cold
Vetteman761
Yea got my motor in guys and the bike will not idle when cold, have to give it throttle till it warms up, before i swapped motors it did not do this, does anyone think that it could be the coolant temp sensor? Or anything else could cause this?
RedBull
New Busa Owner 2004 le | New Owners Forum
Kiwi Rider
Same throttle bodies? Or different set?
Check for fault codes in the ECM, then try turning up the idle at the idle adjustment cable knob, just above the clutch cover.
Vetteman761
Same throttle bodies, checked and no codes, and turned up idle but when it warmed up the idle was at like 3k rpms
Vetteman761
That's where I was going with it too.
Do you have a fuel pressure gauge?
I do not, that wouldnt be a bad place to start huh, i had over winter did the filter mod and put a external one on it , so should be good flow but never checked pressure
VIPER
gne 1 has a fast idle for when cold if i remember right? is thta adjusted.
RedBull
Gen 1
has a
fast idle
for when
cold if I
remember
right ? ? ?
Is that
adjusted ?
:banghead:
Vetteman761
Just checked pressure constant 43ish, and fast idle is off shrug, it didnt need fast idle with other motor and it was cold then outside
Hayabusa Wannabe
If you have a laser thermometer, hit each of the exhausts and see if any of the cylinders have a large variance.
Have you balanced the vacuum/synchronized the throttle bodies? Every motor is going to have different flow in each cylinder.
Vetteman761
Late reply from me but no I have not done that yet, need to get on fleabay or amazon and get synchronizer
