Kaptain Kanji
In the process of taking the Big Girl's front wheel off to replace the tire, I once again noticed that the axle unscrewed with uneven pressure. I had given it a precursory check last time I had it out and didn't see anything wrong with it. I've noticed she pulls to the right and I've been wondering why the tracking was off. Since I have a little time before the dude changes out the tire, I figured I'd check the axle carefully. I put a precision straight edge on the pipe section of it and rotated it. Sure enough, there's a noticeable bend in the tubular section, as in VERY noticeable..!! I guess this would be enough to cause the tracking problem and it definitely needs to be replaced. I got one off FleaBay last night that looks to be in good shape, so when it arrives, I'll check it and if good, install it and make the Big Girl a little happier.!! :-)
Anyway, I guess the moral of the story is, if you unscrew your axle and it doesn't feel like it's turning smoothly, check it for straightness.
If you look at the attached pic, you'll notice the right side of the axle has daylight between it and the scale.!! The left side of the axle is sitting flush with the scale.
