I've got the two nylon pins that are on either side of the rectifier out and even the one 4MM screw by the foot brake lever out. But for the life of me, I cannot seem to be able to separate the belly pan from the rear of the right fairing. I have tried forcing it straight back but nothing gives!? Does the pan push inward or down or what to separate it from the fairing. Or, do you guys just leave it attached to the fairing when you remove the entire fairing (what a hassle that would be!). And some I have read leave the belly pan in place when removing the right fairing, but how did you separate it??
I must be doing something wrong, I am afraid to pull backwards too hard.
Thx in advance.
Thx in advance.
