i just bought a new yuasa batt, the battery charging specs are 12v 1.5amp my battery charger is 12v 2amp. can i cahrge the battery with that charger?
I've got the Jr.
I use a Shumacher full floating charger from Walmart about $20.00, when the battery's charged it stops charging and monitors the battery until it needs to start charging again.
+1 (most ideal IMO)Yes but I'd use a Deltran battery 'tender' Jr. instead.
+1 although option one above is far better in case you forget to turn the charger offIt will be ok
+1 and right back to option 1...Leave it on for 1 hour and then check it with a voltmeter.
12.8 volts is fully charged.
Bike batteries are small and the lead plates are small and you can overcharge them easily.
It won't need any more than 2 or 3 hours unless it was right dead.
option 1+1 (most ideal IMO)
