16nm in this recallguys?
read the gen2´s (´13-´20) manual
in the abs-section they mentioned (if i remember correctely) 17Nm at the flare nuts
easy to check - lift the abs´s alu-cover and wipe the pipes and nuts with a dry finger - if finger gets wet the torques are not ok .
the nut was poorly tightened - so slowly tighten it with a suitable, I mean 12mm (slotted - see pic above) box wrench until the leak is gone.
feel it every now and then with your dry finger.
You mean like Tesla?At least they (Suzuki) have issued a recall and repair and not just simply ignored the issue.
