I asked because I thought the bike would be very lean not for looking for more hpNope
Filters don't make a big difference, a hp or 2, or not, the best thing about aftermarket filters is that they are washable/reuseable.
The k&n will keep more dirt out of the engine(oil analysis) than the Sprint, which basically keeps birds out, lol.
More air flow does mean leaner, but there's not a big enough difference between air filters to need to dyno tune again over changing to a different filter.I asked because I thought the bike would be very lean not for looking for more hp
Perfect tank you so much for you help appreciateMore air flow does mean leaner, but there's not a big enough difference between air filters to need to dyno tune again over changing to a different filter.
I forgot to add air filters to the long list of personal choices we have for our bikes..If you were looking for the last 1-2 HP yes
and K&N would be the wrong choice
But in MOST practical applications NO
Nope
It was already tuned with one...so far correct - but one exception - if you have installed a real racing filter (for racetrack use only), it is actually necessary to tune the engine.
@Raul_923
bmc has both - street and race filters
k&n i guess has only the street version
so leave all at the engine throttle etc. as it is.
Between BMC and Sprint what do you recommendso far correct - but one exception - if you have installed a real racing filter (for racetrack use only), it is actually necessary to tune the engine.
@Raul_923
@Raul_923
So there is not much difference between bmc racing filter and k&n filter?The BMC race is about only about 10mm thinner than the BMC street version, that's it, I've had both, and not worth remapping for.
K&N is thicker than both of them.So there is not much difference between bmc racing filter and k&n filter?
Ok I just want to know if it's worth spending the money or cleaning the one I haveK&N is thicker than both of them.
I have used K&N filters for as long as I can remember.....and they work.Ok I just want to know if it's worth spending the money or cleaning the one I have
Me too but in my carsI have used K&N filters for as long as I can remember.....and they work. If it were me, I'd just clean the one you have and use it.
I've used them in both my cars/trucks and motorcycles for years and years...since the early '80s.....Me too but in my cars
I would clean what you have, there will be no noticeable difference in performance from switching to another brand.Ok I just want to know if it's worth spending the money or cleaning the one I have
Hi. I would look into the one from DNA it is a much better filter than Sprint. I guy on U Tube tested them.Perfect tank you so much for you help appreciate
