I have a gen 1 motor, I installed a spacer plate and APE adjustable cam sprockets, only thing different internal from OEM. When degreeing the cams I set to TDC, and set the end marks on the cams to OEM position, then adjusted from there. I am at 105 intake / 106 exhaust. I checked everything 4 times to be sure. I torqued all bolts to OEM spec. I completed build the other day and went to start, it cranked around 2 or 3 revs slowely then died out like it was a battery issue. Battery was slightly low so I put a charger on it and left on when cranking to see if it made a difference, very slight improvement if any. Then thought maybe the battery just lost the deep cells to crank, I replaced battery and no difference. I pulled 3 of the 4 plugs, to get the 4th one out I would have to pull my charge tube. Thinking if I take the compression of 3 cylinders it should free up enough to crank around easier. It did help some but not as much as I had expected. I also checked the torque on the OEM timing change tensioner to be safe. I had turned the motor by hand at one point to make sure nothing was hanging up or metal banging, valves..etc..
Before I tore the bike down, I started the bike and fired right up. I am about to tear back into it to find the problem but thought I would see if anyone came across this before or things to check.
