I've been offered a good ( I think ) deal on a busa that was run low on oil, its knocking.
The owner swears that the oil light came on then he topped it up, but after a few miles it started to knock.
Question is, can i assume that a crank & rods will fix it?, I quess the cams head journals are next to be damaged? It does run with no smoke. thinking that it would be good for doing a built motor, rods pistons etc......
