houstonbussa Registered Jan 13, 2011 #21 Naw.. Just hit it with some sand paper.. Maybe a hot knife to give it some grooves and you'll be good for another 50k miles or so.. hahaha
RedBull Registered May 22, 2019 #22 red1100cc said: ? ? ? Wow . Nice race slicks ! I try and keep a little more tread on my tire than that . Click around and find a more tour type tire , it might last you a little while longer . Click to expand... Not trying to ask them to do more than they should ~ if you buy a higher number they'll last longer . . . However , that also means that they will not stick nearly as well as the lower number tires ! What I've found out is that the 180 / 55 " HOOK - UP " works great for the drags . I wouldn't ask that tire to perform well heading up to an Idyllwild ride ! The " ADVANCE " 005 would be my choice for curving roads . The " APEX " 010 would last me a little bit longer . Buy whatever you want to go ride with ? I'm OK~ with a cheapo Shinko . Just my two cents here . Red , *<(;{)- Last edited: May 22, 2019
