2012 Not going into 1st or neutral!?!? Please help!!!!
FnIrider76
Hey guys, NEW to the forum and NEW to the site!
I just recently moved up from a 2006 GSXR600 to a 2012 Busa and after my first ride I noticed it would not go into 1st or neutral. I have took the linkage off and tried hand shifting with the same results. I have also tried rocking it back and forth to see if it would engage. Is there a "simple" fix or is the synchronizer out of line/broke????
Any suggestions or help would be great!
Thanks
FnIrider76
FnIrider76
No warranty at all. Bought it used. Called dealer and he said bring it in....big surprise! lol
So has anyone else had this problem?
piratediverjefff
My 2011 is a hassle sometimes going from neutral to first(friend's 2008 is the same way),usually just put light pressure on the shifter and ease the clutch out and will then snick right into gear.
GIXERHP
Pm replied to,,
Sounds like a shifter drum spring is broke.
You need to pull the shifter cover and inspect!
FnIrider76
Thanks guys! I'll let you know what I find when I pull the cover!
GIXERHP
One bolt is a pain in the azz, Just an FYI
ScottyE
I've noticed some times I have to squeeze the clutch lever twice to get mine into first from neutral its like it hasnt built enough pressure with one squeeze to engage . ( Brand new bike)
