VTbusa77
- Joined
- Jan 24, 2009
- Messages
- 23
- Reaction score
- 0
On July 4th I gave the wife a ride to her cousins so they could go to the parade. I then rode back to our house to grab a couple things. All total I put on about 30-35 miles. I then set out for another little ride. About 1/4 way into my ride the bike just stopped running. I was at a stop light on a hill. Light turned green, I let out on the clutch and was up to about 25 mph. As I crest the hill the bike stopped running. I pull the clutch in and look down to see if I accidently put it into neutral. Nope. Looked at kickstand and see maybe I accidently put that down. Nope. Proceeded to pull over to the side of the road. The word "chk" was on the center council. I also then noticed that the temp gauge was pinned all the way to the top. Figuring I may have over heated it, I let it sit for an hour. That did not work. I then got it towed to a local shop that I have been using, not a Suzuki dealership (which I should have). They cannot figure out what the issue is. They tried replacing kickstand switch, they tried a new ignition wiring. Still no luck. Now it is being brought over to a Suzuki dealer to see if they can figure out what is wrong with it.
I was wondering if anyone here has run into or even heard anything like this happening. Any help that can be given will be greatly appreciated. Thank you
