did not know that, thank youThe OEM BT56 measures out to 198MM
Any 200 will fit.
Not all tires measure out the same....but all the 200's will fit.did not know that, thank youThe OEM BT56 measures out to 198MM
Any 200 will fit.
is the 200 a little wider
Not on the Avon Azaro's St's. The 200's turn in like a 180. Really.I’m curious does a 200 look that much fatter and doesn’t it slow the cornering ability?
I cant tell no differance on turnning abilityyou will notice a 200 over a 190 and yes, it will be a little slow in the corners.
what brand of 200 you are looking for?
do i hear 220 going going........Try a 210 if you want the look.
